Check engine light
Old Jan 18, 2013 | 02:43 PM
FrankPerezIII's Avatar
Check engine light
Hello HHr owners. I have a problem I cant figure out. My check engine light is on and wont go off. The code is misfire on cylinder 2. I have had the compression checked- good 125lbs, replaced plugs, replaced coil pack, replaced injector, but still the light comes back on. Dont know what to do???? Help.!!!!
Old Jan 18, 2013 | 03:00 PM
oneton's Avatar
Even after clearing code ?
Old Jan 18, 2013 | 03:02 PM
Yes I have cleared it after I tried all of the above also after I changed the plugs. Keeps coming back.
Old Jan 18, 2013 | 03:06 PM
oneton's Avatar
what about the rubber boot that go's over the spark plug from the coil back.
Old Jan 18, 2013 | 04:04 PM
Lucky's Avatar
I have seen a weak or broken valve spring make misfires. You can check this by doing a running compression check. Can you feel it misfire at idle or higher rpms?
Old Jan 18, 2013 | 04:23 PM
So what code number was that? Is it possible you were given a bad code reading?
Old Jan 18, 2013 | 08:08 PM
Some misfire codes don't mean that a cylinder is actually mis firing. You have to do the entire diagnostic procedure starting with the code number.
Old Jan 27, 2013 | 07:36 PM
safetyjedi's Avatar
I had the same cylinder misfire code and it turned out to be moisture in the fuel system.
Old Jan 27, 2013 | 11:42 PM
"I have had the compression checked- good 125lbs,"
for 10:1 CR that's on the low side.. Did you test COLD or HOT, & was throttle wide open ?
Did you test all 4 holes for comparison ?
Old Jan 28, 2013 | 08:22 AM
solman98's Avatar
Ignition Control Module? Possible open stat?
