Chevy HHR LS 2.2 starting really rough
Old Jul 26, 2020 | 05:34 PM
TrashPaws's Avatar
Good evening everyone! I have a problem. My poor HHR has been starting rough or not even starting at all. I've recently replaced the camshaft position sensor and crankshaft position sensor. I was wondering if anyone had any insight on what to do because right now I'm really lost.
I'm not sure if I can add links to a post but here's a video of what it's doing: https://streamable.com/bhvdlh
Old Jul 26, 2020 | 06:30 PM
What codes were you getting that led you to changing sensors?
Old Jul 26, 2020 | 06:35 PM
TrashPaws's Avatar
The first code was P0016, there was another code for the crankshaft sensor but I don't quite remember what it was.
Old Jul 26, 2020 | 06:44 PM
P0016 is typically a stretched(or worse) timing chain. Do not crank the engine anymore, you will cause catastrophic damage.
Old Jul 26, 2020 | 06:47 PM
Could be your timing chain... Don't drive it until that is confirmed, or you could trash the engine.
TrashPaws's Avatar
But would that cause a hard start or no start at all? I mean I'll definitely look into the timing chain tomorrow as well as everything else.
Old Jul 26, 2020 | 06:48 PM
Yes and yes.
Old Jul 26, 2020 | 06:55 PM
TrashPaws's Avatar
Alright, thanks for your help. I'll check the timing chain tomorrow.
John Mark Smith
Maintenance and Upkeep
Aug 18, 2019 09:02 PM
mrmarkuSS
Sep 29, 2017 06:45 PM
CincyHHR
Jul 27, 2015 12:49 PM
firemanfrank
Apr 12, 2014 06:05 PM
RicT
Sep 10, 2012 05:30 PM
