Code P0442
Hi HHR Guys,
I had my first "Service Engine" light issue ... Code P0442 - Evaporative Emission System Leak (small) If Anyone on this forum had the same problemo - can you please tell me how to repair? :bow: Thanks! |
Any chance you did not have the fuel cap tight? Once the code sets, you need to have it cleared (or a unit like the Aeroforce to clear it yourself). Any number of locations for small leak not allowing the appropriate pressure build-up in fuel tank. Also for 2.0 there is a check valve that can leak.
Originally Posted by c2vette
(Post 426146)
IF code comes back - I would like to know in advance what else can be wrong and how to fix it. Thanks! |
I got the same code in my '08, it was the gas cap bad seal. About $23.00, took care of problem. Any GM dealer has them in stock.
| All times are GMT -5. The time now is 04:08 AM. |
