Coolant Smell
Old Nov 16, 2024 | 09:01 AM
tsbrewers's Avatar
Is the smell mostly inside or outside? Coolant doesn't produce much smell in small amounts until hot, so when the car is hot, typically. Even more if it's getting on something hotter. Follow yer nose. Hunt down that the leak.
Both really, I first smelled it inside the car two days in a row while I was sitting in it while it warmed up, and the last time, I was standing outside the vehicle while it was idling. I plan on checking a few of the ideas out today, to see what I can find. I do have a coolant leak checker where you put a different cap on and pressurize the system to look for external leaks. I will probably give that a try and see what comes of it.
Old Nov 16, 2024 | 09:41 AM
Corrosion at the hose clamps is a clue to look for, that will allow coolant to escape at hot temperature, also air in the system, and look at the weep hole in top of the water pump
Old Nov 16, 2024 | 11:20 AM
greg8453's Avatar
Put it under pressure and see where it's leaking.
Old Nov 17, 2024 | 09:07 AM
The filler neck has been known to crack and crumble.
guppy
Oct 8, 2023 07:15 AM
SSROADSTER
43
Mar 7, 2022 08:46 PM
HHRnovice
Dec 15, 2016 08:46 AM
urbexHHR
Maintenance and Upkeep
May 23, 2012 05:52 PM
denny
Dec 26, 2006 09:04 PM
