Chevy HHR Network
-   -   Coolant Temperatures (https://www.chevyhhr.net/forums/problems-service-repairs-42/coolant-temperatures-59439/)
racing123 Sep 29, 2017 12:57 PM
Issue I'm Having lately, Temps while driving 88C. (190F.)Stopped at a light temps reach 99C.(210F) (No AC on) Outside Temp 20C.(70F) any ideas. Ron.
donbrew Sep 29, 2017 01:03 PM
Sounds normal to me; is this new behavior?
The fan doesn't turn on until about 219F. 190F is about normal for cruising.
RJ_RS_SS_350 Sep 29, 2017 01:05 PM
Engine, trans, miles(Kms). Is this new behavior, if not, what preceded it?
Sounds just a tic high. When was the DexCool last changed?Even in an open system, 210* is not boiling; with the pressure, it's nowhere near boiling.
Oldblue Sep 29, 2017 01:05 PM
Year?
Engine?
Last coolant change?
What coolant was used?
Last thermostat change?
What stat was installed?
Was all the air burped out of the system?
All seem odd questions, however the HHR would be at least 6 years old , and so is past due for the coolant change.
These trucklets are designed for Dexcool 50/50 mixed with distilled water and the AC Delco thermostat.
racing123 Sep 29, 2017 01:09 PM
yes just started yesterday, previous with outside temps at 85F, Air on, Temps would not reach 190F at idle. ?? tnx.
racing123 Sep 29, 2017 01:15 PM
2009 Panel, 12300 miles, coolant is original i assume,
RJ_RS_SS_350 Sep 29, 2017 01:42 PM
OK, so if original, your coolant is right around 8 years old. DexCool has a maximum service life of 5 years. It's doing an adequate job at cooling/freeze protection, but the rust inhibitors are used up, and your engine may be starting to corrode on the inside, which also damages the coolant.
Time for a flush and a new ACDelco 131-158 thermostat. GM P/N 12622410
If you cheap out on the thermostat, you will probably have issues.
racing123 Sep 29, 2017 01:47 PM
Thank You RJ R.
firemangeorge Sep 29, 2017 02:39 PM
(attn. One of the Mods should move this thread to the appropriate section )
Oldblue Sep 29, 2017 03:01 PM
Hold on , nothing up my sleeves!! Presto it’s moved!
