Cooling Fan won't run
The Cooling fan won't come on, burned up my a/c compressor. This fan should run when the a/c is running. Does anyone know where the sencor is for this fan, I don't have a repair manual. Can anyone help me with this problem.
Can you make the fan run ? Find the ter. that turns on the fan from the fan relay. make a jumper and put power to that ter. with relay removed to see if the fan motor will run. If it does then it's not the fan motor. I find it hard to think that the fan not working will burn up the A/C comp. If the fan did not go on the the High side press will go up and the high press switch will turn off the comp.
Is your car overheating or running hotter then it use to? If you let the car idle will fan come on, it will take some time for it to come on like 15-20 min. if outside air temp is not to high.
new to working with fusebox, how to make jumper?
thanks!
My fan just stopped working, replaced blown fuse, still not working.
You’ve dug up a thread from 15 years ago.
Besides that, member oneton hasn’t logged in here since 2014.
