Cooling System Flush, 2.2L
I am about to flush my cooling system (have done this with all my vehicles over many years). My concern is that it appears that my '08 LS 2.2's cooling system works in reverse of the cooling systems that I'm accustomed to and that are pictured on the Prestone Flush 'n Fill Kit's instructions. The instructions say to install the tee in the "heater inlet hose" and shows a typical, old-style V-8 or Inline-6 engine with the thermostat housing at the end of the top radiator hose, connecting to the intake manifold. So the thermostat on those engines controls the flow of heated coolant OUT of the engine, into the top of the radiator. Flushing through the heater inlet hose, therefore, allows a back-flushing through the heater core, out the heater outlet hose, through the water pump, through the bottom radiator hose, and up through the radiator (as well as down through the engine, via the heater bypass south of the thermostat housing, and out through the water pump, up through the radiator).
The 2.2's thermostat apparently controls the flow of cooled coolant INTO the engine via the bottom radiator hose. So it appears that, unless the engine reaches ~180 degrees to open the thermostat during the flush, I won't get a backflow up through the radiator, regardless of which heater hose I use to install the flush tee, since it appears the heater outlet hose connects to the thermostat bay on the engine side of the thermostat. In other words, regardless of which heater hose I use to install the flush tee, it appears that my flushing will for the most part just reach the heater core and the engine, flowing out through the fill cap in the top radiator hose, with some unpressurized flow down through the radiator via gravity. Can anyone confirm this and give any input regarding my attempt at an effective flush? I have considered starting with a fully warmed engine to get at least a little back-flushing action through the bottom hose before the t-stat closes. I currently have a radiator flush product in the system and want to get all of that out before installing new coolant along with a new radiator and cooling fan (blades somehow broke off and damaged the radiator). Also, since the heater OUTLET hose is more accessible and further from the heat of the exhaust (the heater inlet hose has a foil insulation around it from the factory), does anyone have an opinion as to using the heater OUTLET hose for the tee, if the flow pattern described above is correct? |
Not sure if this thread should be moved to the Maintenance and Upkeep forum. I'm new to this site (spent a number of hours reading already) and not sure exactly how things are done around here. Moderators, I welcome any corrections/adjustments or instruction, as appropriate.
Since this thread is a duplicate of the post you opened elsewhere (on that old thread), I'll close this one,as the old thread might offer better continuity for your questions.
Making duplicate posts, just makes it too confusing for everyone to follow. |
| All times are GMT -5. The time now is 05:43 AM. |
