Crank postitoning sensor
P0010 is the cam shaft intake actuator. (I just replaced mine)
https://www.chevyhhr.net/forums/how-tutorial-library-21/camshaft-position-actuator-solenoid-valve-replacement-w-pics-p0010-11-p0013-14-a-28779/
(My post is around #219)
You don't. Message appears along with a CEL
O-Ring is lubricated with engine oil.
Are you saying that since the CPS replacement you have tried to clear the code and it resets immediately?
Let's start with basics here. What diagnosis did you use to arrive at replacing the crankshaft position sensor?
