Chevy HHR Network
-   -   Crank postitoning sensor (https://www.chevyhhr.net/forums/problems-service-repairs-42/crank-postitoning-sensor-44943/)
mr chevelle Feb 19, 2013 07:51 AM
I replaced the crank sensor ,now i have 2 codes p0010,and p0335,how is this posible when only had p0335 befor please help me
prod Feb 19, 2013 08:19 AM
Did you do a relearn?
mr chevelle Feb 19, 2013 09:41 AM
crank sensor
how do you relearn crank sensor ,chilton book does not help
Putter Feb 19, 2013 11:07 AM
P0010 is the cam shaft intake actuator. (I just replaced mine)
https://www.chevyhhr.net/forums/how-tutorial-library-21/camshaft-position-actuator-solenoid-valve-replacement-w-pics-p0010-11-p0013-14-a-28779/
(My post is around #219)
ChevyMgr Feb 19, 2013 11:12 AM
Did you clear the P0335 after the replacement of the sensor?
mr chevelle Feb 19, 2013 01:35 PM
how do you clear code i went to auto zone they could not clear code also have code p0010 now after replacing crank sensor
mr chevelle Feb 19, 2013 01:37 PM
how do you service traction control
mr chevelle Feb 19, 2013 02:11 PM
are you to put lubercant on crank sensor when installing it chilton manual did not mention this
ChevyMgr Feb 19, 2013 03:24 PM
You don't. Message appears along with a CEL
O-Ring is lubricated with engine oil.
Are you saying that since the CPS replacement you have tried to clear the code and it resets immediately?
Let's start with basics here. What diagnosis did you use to arrive at replacing the crankshaft position sensor?
mr chevelle Feb 19, 2013 05:39 PM
code p0335
