Cranks fine but won't start on first try!
Old Sep 16, 2025 | 12:58 AM
SpaceJockey's Avatar
Question Cranks fine but won't start on first try!
Hi all,
I have a 2007 HHR 2.4 (Automatic Trans) 130,000 miles
Crank speed is normal but will not start on first try, will start and runs perfectly on second or third try. There are no drivability issues or engine roughness when driving,
Here is what I have checked and or tried:
1. Scanned for codes with a bi-directional scan tool (Innova 5160 not the greatest I know) no codes are present and there are no lights (SES) on IC.
2. Checked for pressure at injector fuel rail Schrader valve after just a few minutes of engine being keyed off, no pressure or fuel comes out! (when fuel pressure gauge /tester is available at local parts store I plan to borrow and check for pressure when running.)
3. Looked for and "smelled" for fuel leaks around engine compartment and under back near fuel tank, nothing observed anywhere, no signs of a leak I can detect.
4. Swapped fuel pump relay with identical part, known to be good (No effect)
Anyone have a similar issue with a diagnosis?
Thanks!
Old Sep 16, 2025 | 07:37 AM
Seems to be the fuel pump assembly not holding pressure.
Old Sep 16, 2025 | 08:04 AM
The fuel pressure should not lose more than 5 psi in 1 minute after key off.
The pump only runs for a few seconds if the engine does not start.
Don't hold the key when starting, just turn it to start and let go.
Old Sep 16, 2025 | 08:32 AM
Lonwane's Avatar
2006 2LT, auto, 235,000 miles
SISU has been like that since I brought her home, although, sometimes she starts on the first try.
I've owned her for 8 years with this issue.
I have learned to live with it as changing the fuel pump is a PITA.
Old Sep 16, 2025 | 09:41 PM
"Seems to be the fuel pump assembly not holding pressure."
Thanks, that's what it seems like with the quick loss of pressure.
Old Sep 16, 2025 | 09:43 PM
Thanks, yes it does this whether I use remote start, bump the key, or hold in start position.
Old Sep 17, 2025 | 11:28 PM
PulpFriction's Avatar
Here's an experiment to try on a cold start. Turn the Ignition on, but not to start. Listen for the fuel pump. It should only go for just a couple seconds. Turn it off. Repeat.Maybe even a third time.Then turn the key all the way to start. Betcha with the system thus primed, it will start the 1st time. If so, it's the chech valve, as previously mentioned.
This bears repeating; it's not necessary to hold the key in the start position until it starts. That's for old-fashioned cars. Just turn it momeitarily . That initiates the start sequence.
stylo_guy
May 28, 2024 09:28 AM
rgatijnet
Aug 23, 2021 09:09 PM
Lonwane
Sep 2, 2020 02:30 PM
Rolly
Jun 24, 2017 07:00 PM
graydog
Jan 9, 2009 05:23 PM
