Crankshaft sensor and camshaft sensor, P0016 code - Chevy HHR Network
Closed Thread
Thread Tools Search this Thread
Old 02-05-2018, 09:28 PM   #1
Question Crankshaft sensor and camshaft sensor, P0016 code
(2008 HHR) I was given the code P0016 and it said crankshaft sensor and camshaft sensor. First I don't know where either are locate. Also is either sensor the problem or the chain belt like someone told me. I like your thoughts on that and help me locate both sensors. (I hope my topic is in the right place).
Slick360 is offline
Old 02-05-2018, 09:35 PM   #2
Hi Slick, to the forums!!
P0016 is extremely likely the timing chain.
RJ_RS_SS_350 is offline
Old 02-05-2018, 09:50 PM   #3
RJ_RS_SS_350
I don't know what to do because the car won't start nor run and am wondering since I brought crankshaft sensor and may buy camshaft sensor should I put it on or get it towed. Thanks for the input.
Slick360 is offline
Old 02-05-2018, 09:56 PM   #4
If you can't replace the timing set yourself, then you will have to tow it to a competent shop. If you want to verify that it is the timing set, you can pull the valve cover and see if there is slop in the chain.
It is not a problem with the sensors, it is a problem with what they are sensing. The camshaft and crankshaft are not in sync.
Old 02-05-2018, 10:07 PM   #5
I would look at it tomorrow morning, if you don't mind I'll keep you posted because I'm new at this. Once again thanks.
Slick360 is offline
Old 02-05-2018, 10:11 PM   #6
Your welcome. Please keep it to this one thread, to avoid confusion.
Old 02-05-2018, 10:15 PM   #7
I'm new on here so I did put another thread because I didn't know where to post it. But getting help from you and this problem I'll keep it here for now on.
Slick360 is offline
Old 02-05-2018, 10:22 PM   #8
Senior Moderator
Best of luck with it - RJ is definitly pointing you in the right direction.
whopper is offline
Old 02-06-2018, 09:09 AM   #9
RJ has you going in the right direction, which engine you have? The chain kits are different .
P0016 indicates the timing chain is off a tooth or two , do not try to start it again.
Oldblue is offline
Old 02-06-2018, 01:45 PM   #10
Old blue
My car won't start at all. 2.2 is my engine. I really don't know nothing about cars. The simple things I can do by watching YouTube channels. This morning I tried to look into the tooth's, by taking off the valve cover off and that's allot for me, (like RJ_RS_SS_350 suggested) but there's allot to take off and it's beyond my pay grade. Even the camshaft sensor is all the way in the bottom under the oil filter I believe and like I said it's beyond. I must do something because the money to do all this is too much. I wish I had a trust worthy machinic (misspell).. I KNOW I HAVE TO START LEARNING.
Slick360 is offline
Closed Thread
Thread Thread Starter Forum Replies Last Post
Camshaft position sensor problem, Code P0341 HHRfred2008 Problems/Service/Repairs 3 05-01-2017 03:47 PM
camshaft and crankshaft position secsor's CincyHHR Problems/Service/Repairs 8 07-27-2015 01:49 PM
Camshaft and crankshaft Position Actuator Solenoid correct parts Gsus Problems/Service/Repairs 3 02-04-2015 11:58 AM
Help needed - Scanner code, locate camshaft position sensor jojo33 Problems/Service/Repairs 20 05-20-2013 01:02 PM
Camshaft Error thrown, but HHR has no camshaft.. Ceashure Problems/Service/Repairs 15 01-11-2013 05:15 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Copyright © 2005 - 2017 Internet Brands, Inc. All rights reserved.
