Crankshaft sensor and camshaft sensor, P0016 code - Page 4 - Chevy HHR Network
Closed Thread
Thread Tools Search this Thread
Old 02-13-2018, 01:14 PM   #31
Firemangeorge, thanks. I do mean the valve cover. I appreciate it.
Slick360 is offline
Old 02-13-2018, 01:33 PM   #32
By the way, you canít see all the timing marks with out removing the valve cover and the front engine cover.
Oldblue is offline
Old 02-13-2018, 01:39 PM   #33
Technical Moderator
A mechanic that thinks all 4 plugs spark at all times the ignition is turned on?
Stay away from that guy!
donbrew is online now
Old 02-13-2018, 01:40 PM   #34
Here’s what damage could occur, turning over the engine
https://images.google.ca/imgres?imgu...ce=sh%2Fx%2Fim
Oldblue is offline
Old 02-13-2018, 01:42 PM   #35
Thanks donbrew.
oldblue, I wanted to see if the chain is loose from the top after I take off the valve cover.
Thanks EVERYBODY for the help.
Slick360 is offline
Old 02-13-2018, 03:07 PM   #36
Loose doesn’t matter, out of time does!
Oldblue is offline
Old 02-13-2018, 03:14 PM   #37
Senior Moderator
Quote:
Originally Posted by Slick360 View Post
The way he checked it was: spark plug was still connected to the wire outside its pocket where it goes in. I turned the key and it didn't spark. He than placed a new spark plugs onto the wire and than I turned the key and it than sparked.... I can take suggestions easy. But you don't have to give smart comments when I asked something or I forget to write the entire senerio of what happen. Like you said this site is to point us to the right direction which means help, so when I asked a question why not keep it simple and do just that
Look - you better take it to a mechanic - one that knows that they are doing.
You still don't get it - turning the key and it didn't spark? Well guess what man, of course it will not spark, not unless the engine is turned over. It's not rocket science. And since you said you had not turned the engine over (ie: not started nor attempted to start it) guess what? The so-called mechanic lied to you.
We have tried to keep it simple - but it can only be so simple.
so end of my "smart comments" - have fun
whopper is offline
Old 02-13-2018, 03:24 PM   #38
Thanks everybody. Thanks everybody for letting me know what to do and the steps to do it. I'm not rich so therefore I have to TRY to do it myself. Regardless I have to learn. Besides I'm so tiered of mechanics taking advantage of my ignorance of cars and charging me to much than to find out other wise. Thanks again everyone
Slick360 is offline
Old 02-13-2018, 03:37 PM   #39
Whopper, thanks. That's what I'ma do. I'll still place some new spark plugs but I do believe you and everybody else that the spark plugs isn't the only problem. I rather take all y'all advice than the mechanic I'm dealing with
Slick360 is offline
Old 02-13-2018, 11:04 PM   #40
To restate what has been said, another way - if any spark plugs sparked, you were turning the engine over, risking catastrophic damage to the engine.
RJ_RS_SS_350 is offline
Closed Thread
Thread Thread Starter Forum Replies Last Post
Camshaft position sensor problem, Code P0341 HHRfred2008 Problems/Service/Repairs 3 05-01-2017 03:47 PM
camshaft and crankshaft position secsor's CincyHHR Problems/Service/Repairs 8 07-27-2015 01:49 PM
Camshaft and crankshaft Position Actuator Solenoid correct parts Gsus Problems/Service/Repairs 3 02-04-2015 11:58 AM
Help needed - Scanner code, locate camshaft position sensor jojo33 Problems/Service/Repairs 20 05-20-2013 01:02 PM
Camshaft Error thrown, but HHR has no camshaft.. Ceashure Problems/Service/Repairs 15 01-11-2013 05:15 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Copyright © 2005 - 2017 Internet Brands, Inc. All rights reserved.
