cruise control won’t resume
Old Feb 16, 2023 | 01:51 PM
jteemo's Avatar
Hello group: I have just purchased a 2007 hhr panel lt. My cruise control will engage but will mot resume or increase the speed. Have anyone here experinced this and what was the solution.
Old Feb 16, 2023 | 02:06 PM
Welcome to the site. The cruise control switches in the steering wheel might be worn out.
https://www.rockauto.com/en/catalog/...ol+switch,4320
Old Feb 16, 2023 | 03:24 PM
greg8453's Avatar
Agree with oldblue.
Old Feb 16, 2023 | 03:34 PM
jteemo's Avatar
Thanks a bunch, just ordered a new switch, will update with the results
Old Feb 16, 2023 | 05:49 PM
How are you trying to resume? By the directions in the Owner Manual? You have to be moving over 25 MPH. It won't resume if you slowed down more than about 10 MPH
Is the CheckEngineLight on? Are the brake lights stuck on?
Old Feb 16, 2023 | 06:53 PM
Post #1 says cruise will engage, just not resume or increase speed, so by that I think there’s no CEL and the brake lights are functioning
To access the steering wheel switches, see page post #32 from this post in the way back machine!
https://www.chevyhhr.net/forums/how-...el-1912/page4/
Be sure to disconnect the negative terminal on the battery and put a shop towel on the latch so the hatch can’t close.
Old Feb 16, 2023 | 06:57 PM
If the new switch doesn’t fix it, you may be looking at a bad clock spring.
Old Feb 16, 2023 | 06:58 PM
Wouldn’t a bad clock spring take out all those buttons?
Old Feb 17, 2023 | 07:40 AM
jteemo's Avatar
It won't resume no matter what my speed is at this time. But it will set and when I cancel it it want return to the original speed or it want advance.
Old Feb 17, 2023 | 08:49 AM
Lonwane's Avatar
How is the cruise cancelled?
If with the brake then resume should work.
If with the steering wheel button then the cruise must be engaged again.
