Chevy HHR Network
-   -   cruise control won’t resume (https://www.chevyhhr.net/forums/problems-service-repairs-42/cruise-control-won%92t-resume-66008/)
jteemo Feb 16, 2023 01:51 PM
Hello group: I have just purchased a 2007 hhr panel lt. My cruise control will engage but will mot resume or increase the speed. Have anyone here experinced this and what was the solution.
Oldblue Feb 16, 2023 02:06 PM
Welcome to the site. The cruise control switches in the steering wheel might be worn out.
https://www.rockauto.com/en/catalog/...ol+switch,4320
greg8453 Feb 16, 2023 03:24 PM
Agree with oldblue.
jteemo Feb 16, 2023 03:34 PM
Thanks a bunch, just ordered a new switch, will update with the results
donbrew Feb 16, 2023 05:49 PM
How are you trying to resume? By the directions in the Owner Manual? You have to be moving over 25 MPH. It won't resume if you slowed down more than about 10 MPH
Is the CheckEngineLight on? Are the brake lights stuck on?
Oldblue Feb 16, 2023 06:53 PM
Post #1 says cruise will engage, just not resume or increase speed, so by that I think there’s no CEL and the brake lights are functioning
To access the steering wheel switches, see page post #32 from this post in the way back machine!
https://www.chevyhhr.net/forums/how-...el-1912/page4/
Be sure to disconnect the negative terminal on the battery and put a shop towel on the latch so the hatch can’t close.
firemangeorge Feb 16, 2023 06:57 PM
If the new switch doesn’t fix it, you may be looking at a bad clock spring.
Oldblue Feb 16, 2023 06:58 PM
Wouldn’t a bad clock spring take out all those buttons?
jteemo Feb 17, 2023 07:40 AM
It won't resume no matter what my speed is at this time. But it will set and when I cancel it it want return to the original speed or it want advance.
Lonwane Feb 17, 2023 08:49 AM
How is the cruise cancelled?
If with the brake then resume should work.
If with the steering wheel button then the cruise must be engaged again.
