Dash Storage Bin Repair
The right side of my dash storage bin is a tad higher than the rest. Upon opening the door, I can see where the top Grey part of the door is not properly snapped into the underside black part of the door. How do these two pieces come apart or are they glued together?
They are sold as one part, I don't know if they will come apart without damage. The box comes out after you remove the 2 screws in the front, there may be a couple of friction tabs.
06 11 Chey HHR Dark Gray Center Dash Top Glove Box Storage Compartment Door | eBay |
They get screwed up by overloading them and then forcing the top door to close.
New ones are available @ approx. $125. Or .. Check a wrecking yard but be care full you get one that is installed so you can see how it works and fits. I would also take your old one with you to check color match. They can get faded from the sun. |
