Dic and door locks
Old Oct 25, 2009 | 05:16 PM
DANNY HUNTER's Avatar
Dic and door locks
HELLO ALL. JUST A SMALL PROBLEM I CANT FIGURE OUT. I HAVE A 2008 HHR LT 2.4 AND WAS TRYING TO GET THE DOOR LOCKS TO STAY LOCKED WHEN I PUT IT IN PARK. THEY AUTOMATICALY UNLOCK WHEN PUT INTO PARK NOW. I READ THE MANUAL AND WHEN I HOLD THE RESET BUTTON AND INFO DOWN AT THE SAME TIME, I GET NO PERSONALIZATION MENU. I TRIED IT WITH MOTOR RUNNING, MOTOR OFF, IN PARK, IN NEUTRAL. ALL I GET IS THE STANDARD MENU, TIRE ,TRIP, MPG, AVG SPEED, ETC. WHAT AM I DOING WRONG?
Old Oct 25, 2009 | 05:42 PM
oneton's Avatar
Press and hold info & reset buttons at the same time for one second then release. then press the info. button to schrool through the settings. press the reset button to scroll through the setting on each mode you want to change.. Hope this helps.
Old Oct 27, 2009 | 12:06 PM
Yea, thats just what i did, just like the manual said. Still would not go into personalization mode. Im wondering if its broke. I have no other problems with anything on the little car. Great ride
Old Nov 23, 2009 | 05:19 PM
You did not mention "ignition on, engine not running".
Old Nov 24, 2009 | 09:47 PM
Comfortably Numb's Avatar
I have no idea on getting into the personalisation menu, it sounds like there is a problem that needs fixing. But in my vehicle there is nothing you can do to keep doors locked when the vehicle is put in Park. It even says so in the Owners Manual. The only thing that can be selected is unlocking the driver door or all doors. Good Luck with whatever happens.
Old Nov 25, 2009 | 01:03 AM
Mine too..
If I an sitting somewhere & want the doors to remain locked with motor running, I just bump it into neutral & apply the park brake..
Old Nov 25, 2009 | 11:31 PM
Originally Posted by SSguy
Mine too..
Why not just put it in park and hit the door lock button? SOP for hitting drive up ATMs.
Old Nov 25, 2009 | 11:49 PM
Talking
Too easy..............
Old Nov 26, 2009 | 12:43 AM
outlandishhhr's Avatar
Mine doesn't unlock until I turn the key off.
Old Nov 26, 2009 | 08:06 AM
TomsHHR's Avatar
Try Ignition off, Press and hold info & reset buttons at the same time, turn ignition only on (do not start the engine) then release. then press the info. button to scroll through the settings.
