Chevy HHR Network
-   -   door locks (https://www.chevyhhr.net/forums/problems-service-repairs-42/door-locks-37366/)
tntwolt Sep 14, 2011 08:23 PM
door locks
okay, what is it with power door locks. no problem with locking, or remote starting, but unlocking the cotton picking doors! wifey gets pissed while i run around an open door then unlock hers. y`all notice they don`t put key cylinders in pass door for years now.
843de Sep 14, 2011 09:34 PM
Sounds like you might have worn contacts in your key fob, at least that's what I'm reading into your post. can you elaborate on the issue a bit more.
mroney Sep 14, 2011 09:38 PM
Easy enough to check. Open the fob and put something metal accross the contacts on the board. Thats how I found mine bad. You can get the pad insert on Ebay for less than $10.
tntwolt Sep 17, 2011 09:42 AM
yeah it was the button. fixed it the yankee ingenuity way, super glue foil on both buttons. cheeep!
SmootHHR Sep 17, 2011 10:19 AM
I wouldn't mind seeing some pics of that if you have some time. Wifey's fob doesn't work and I'm thinking that's it. Had it resoldered and new battery...still nada.
tim_tenn Sep 17, 2011 02:36 PM
Having problems with my locks on the driver side, both front and rear door. Sometimes they lock, sometimes they don't (using key fob, or when moving in and out of gear). Not a fob issue as everything else works. Guess I'm going to have to pull the door panels and check them from there.
tntwolt Sep 17, 2011 02:59 PM
just cut about a 1/8 inch square of aluminum foil and a drop of superglue on the button with a toothpick or something. give it a minute or so to dry and thats it. i did lock/unlock buttons.
SmootHHR Sep 17, 2011 05:11 PM
I'll have to try that out. Thanks
Budster Sep 18, 2011 06:56 PM
After reading this thread I decided to try the foil/super glue fix and wa-la, it works great, no more hitting and hitting the button, just a light touch and the doors open. Thanks to this group for a great idea! gotta love the internet :thumb:
