Door unlock and lock while driving, shifter in the transsmisiongoes crazy
It’s most likely the solenoid in the gear selector. Try lubricating the plunge.
That extra ground wire doesn’t resolve the ground wire issue, trace back the ground wire for the TCM look for loose ground wire, it attaches to the driver’s side strut tower.
changing the gear selector is 4 … 10 mm fasteners and the shift cable and the light in the PRNDL
My solution was so simple i cant belive it! Listen
The door lock was worn out, so the chip in the door thinks that door are open when You drive (D), my solution was to use the Insulating tape on all the metals that door are hooker when You close them, the metal things on the body where the lock locks. make a coatin from Insulating tape on them i made 10 spins, problem solved.
I miss my HHR
Hello, strange thing
i sold the car last friday but, after 2 year of fighting i managed to solve the problem!
I miss my HHR
I miss my HHR
I don’t think the same solution will work for me because my car is a 2007 Tahoe When the door opens while driving, the car does not shift into P like modern cars do.
I thought my problem might be similar to yours because while driving the gear keeps switching repeatedly between D and P, and sometimes 2, along with all the doors locking and unlocking and a loss of power.
However, when the car comes to a complete stop nothing happens. But when I stop and put the car in N, and then press the gas pedal, it starts switching repeatedly between D and P.
Hello, thank you for replying after all these years 🙃. It’s good to hear that you eventually found a solution after all your attempts. I don’t think the Chevy Tahoe and the HHR are very similar internally.
I think that you may also chec the locking system.
I dont know the tahoe car.
What would i do check all the grounds in the car, check all the abs sensors, and check the cables in doors, specaly the wires betwen door and body, start from the driver side. If that will not help check the shifter solenoid. And maybe the transmission gear fluid is low or old ? What was checked in my HHR is BCM and the comfort module (in my chevy they ware glued solid) Also try to tighten the fuse boxes.
Nope other than the bow tie , your selector is on the steering column, the HHR is on the floor
parts supplier might be the same but the parts are of a different design.
I agree to try some of the things in the above posts .
littlehoov
Jan 19, 2016 04:20 PM
jbbadboy
Jan 12, 2016 12:11 PM
