Drivers door window switch problems
Old May 27, 2015 | 11:50 AM
Doctor Who's Avatar
I have been having a problem with the window switches on the drivers side door not wanting to work the windows. The drivers door window seems to work ok with the switch and I can use the switches on the other doors and they work fine but not with the switch panel on the drivers door.
Any idea what is wrong and how to fix it?
Old May 27, 2015 | 12:10 PM
Most likely water has gotten into the switch. Replacement probably.
Does the door speaker still work?
Does the mirror switch still work?
Old May 27, 2015 | 12:12 PM
A specific reason for them not working - nope. But you can start troubleshooting to eliminate possible causes: The switches themselves, the connection to the switch panel, the wiring to the switches, etc.. and look for water damage at the same time on the switch panel.
You will need a Volt/Ohm meter to do the tests to verify if the switches are working, as well as the wiring harness itself.
Old May 27, 2015 | 12:25 PM
Doctor Who's Avatar
Yes and Yes.
Old May 31, 2015 | 09:03 AM
Doctor Who's Avatar
I am not one to take buy a new one as fix so I took the switch out and took it apart. I cleaned the contacts inside with a red rubber eraser and that seems to have fixed it. There some black goo on the contacts. I guess age or moisture may have caused it to not make good contact. Either way, it seems to be working now. Thanks for the advice.
Old May 31, 2015 | 10:23 AM
Good fix. Glad you got it working again.
Old May 31, 2015 | 11:27 AM
Awesome news!
CJ3
Aug 25, 2014 02:54 PM
pstar
Jun 9, 2014 06:14 PM
VinceP
Mods - Interior
May 14, 2011 12:15 AM
2010SilverIceSS
Jan 19, 2011 08:17 PM
airbuff1
Mar 5, 2007 01:15 PM
