Drivers wiper arm rubs on hood when arm is lifted?
Old May 25, 2007 | 01:49 PM
Goose's Avatar
I'll check it out...thanks Snoopy!
Goose
Old May 25, 2007 | 01:51 PM
mizzouHHR's Avatar
I'm with Snoopy. Mine to not touch the hood when raised, and I have no paint marks on the edge of the hood.
Old May 25, 2007 | 07:05 PM
nfboy's Avatar
Originally Posted by Snoopy
If your wipers are adjusted for the correct sweep......
When turned off they should stop with the top of the blade on the "spot" indicators located on the OEM windshields....one on the lower passenger side, for the passenger wiper....one just off low center for the drivers side.
My wipers do not touch any part of the hood.
I only just noticed the indicators on the windshield this past weekend. My wipers line up perfectly with them and do not touch the hood in any way when up either.
Old May 25, 2007 | 07:31 PM
captain howdy's Avatar
I haven't noticed any rubbing and my wipers clear my hood just fine. For the hell of it I did a quick check of the gaps. Roughly 3/4" clearance on the passenger side and 1/4" on the drivers side. If your wipers rub your hood then you have a problem.
Old May 25, 2007 | 09:28 PM
Applenut's Avatar
Good info....will look tomorrow!
Old May 25, 2007 | 10:57 PM
Goose's Avatar
That's it I have had enough....I have a problem I guess...car is going back tomorrow......................
Well my wipers as well as the other guys here must have our wipers misaligned...NHHHR...I'd check yours...I noticed this at the dealer and checked out your HHR (thought it touched) and on the Imp Blue one...the Imp Blue one did not touch
I'm guessing this can be adjusted byt the dealer or is it a DIY?
Goose
Old May 25, 2007 | 11:00 PM
Applenut's Avatar
it's a DIY, 15mm socket, open hood, remove plastic cap from bottom of wiper arm, loosen and adjust...
Old May 25, 2007 | 11:02 PM
jwolfe99's Avatar
I'm guessing this can be adjusted byt the dealer or is it a DIY? Goose
I am going to check mine in the morning just to make sure. Goose the dealer should be able to adjust them with no problems, should be a relatively quick fix.
Old May 26, 2007 | 12:00 AM
Goose's Avatar
Thanks Apple..will check it out
Goose
Old May 26, 2007 | 12:10 AM
dbarberaz's Avatar
Never noticed, guess in the morning I will have to look
