Electric latch & sunroof
Guys my sunroof suddenly stopped working along with the rear hatch latch seldom opening with the touch pad. Are these wired together? Which relay would I check? I replaced the latch and the touch pad but it still only works on rare occasions. I have checked all fuses and they are fine. What to do next?
1 Attachment(s)
It looks like the sun roof and the lift gate are powered with the same fuse so those two problem could be related.
Check fuse number 10 in the under hood fuse box. Make sure it is tight and good. |
