Steering Wheel Lock
Steering Wheel Lock
I have a problem with my steering column. When I park the car with the wheels straight ahead, the steering wheel does not lock when I remove the key. If the wheels are one full turn to the left and I remove the key, the steering wheel locks. I asked the dealer about this and he said that some cars don't come with locking steering. I know I am going to have a problem getting the dealer to repair this problem and was wondering if many other members have experienced this problem with their steering wheel not locking upon key removal. Was there a possible recall for this problem?
Thanks in Advance
Tanduay
Canada
Thanks in Advance
Tanduay
Canada
ive had that issue with my cobalt once in a while
have you tried to remove the key and turn the wheel untill it locks ?
thats what i do for mine espicually when im parking on a hill i turn the wheels so i can park and not worry about it rolling all the way down the hill
The steering wheel lock is not as "prominent" as it once was. If you remove the key with the wheel centered, it will not feel "locked" until you (or the thief) attempts to turn the wheel. It should lock once the wheel is turned a distance to one side or the other. Try that with yours. If it doesn't lock at all with the key removed and the wheel turned, then you have a problem.
If I remember correctly, it only locks once you turn it more than 90 degrees off center. It wont stop a thief from taking off, but he wont be able to turn a corner.
What part of Ontario are you from?
