electrical
Old Apr 28, 2018 | 09:11 AM
Dally's Avatar
Question electrical
I have a 2006 HHR and the hi beam headlights won't shut off, I have checked the relay replaced the turn signal stock to no avail anyone have any info on this problem
Thanks Don
Old Apr 28, 2018 | 09:23 AM
gio89kid's Avatar
Sounds like you have a stuck high beam relay. But, if you checked it, I am not sure?
So it is always on while driving or is it on right now in the parking lot?
Old Apr 28, 2018 | 09:36 AM
Is this new? What happened just before it started?
If nobody messed with wiring the only place to look is the relay.
The switch sends a signal to the BCM, the BCM sends a signal to the relay.
Dally's Avatar
electrical
Thanks for your reply. yes the hi beams are on all the time, to shut them off I pull the relay but the hi beam indicator on the dash remains on I have tried changing the relay to no avail.
Don
Old Apr 28, 2018 | 09:42 AM
Then the wires between the switch and the BCM have been messed with because the indicator light is on a serial data line.
Something is telling the BCM to turn the high beams on.
Dally's Avatar
Thanks donbrew the problem started after the car had been parked for a few days, my neighbor across the street noticed the lights on and told me
Old Apr 28, 2018 | 10:02 AM
Varmints nesting and eating wires?
After market alarm?
Old Apr 28, 2018 | 10:13 AM
Silverfox's Avatar
Have you tried using your Auto lite switch to turn head lights off as a temporary measure until you get it figured out ??
It will work with or without the motor running.
To turn off you use the turn signal arm and twist the switch on the end to the right all the way.
Just a thought ....
SF
Old Apr 28, 2018 | 11:12 AM
Dally's Avatar
Thanks Silverfox tried that and no luck
D
Old Apr 30, 2018 | 09:35 AM
The multiswitch could have failed, mine was the culprit a few years ago.
halfpanel08
Jun 28, 2008 06:45 PM
2ofthemincali
Jun 15, 2008 06:34 PM
Crlgrl
Mar 30, 2008 01:57 PM
c2vette
Mar 9, 2008 06:25 PM
Lone Ranger
Jun 15, 2007 02:53 AM
