Electrical Nightmare
Old Feb 15, 2020 | 12:30 PM
GreyHHR#2009's Avatar
I have a 2009 Chevy HHR LT. Only the Drivers window works from the New drivers window controller. You can hear the other windows click but no action.Did not find any damaged wires between the door and body.The ground from the switch to body is good.All fuses are good and have power to them.Took apart the driver rear door and the Green wire is HOT black ground is good.Nothing worked before I replaced the drivers door switch assembly.
Old Feb 15, 2020 | 01:56 PM
The 2 wires from the switch go directly to the driver window motor. Power and ground are common.
So, bad LF switch, bad motor, bad wires or bad mechanism are the only choices. If you hear the motor trying then it is the regulator/motor assembly.
I am so confused; which windows work?
The 2 wires to the motors reverse polarity depending on the direction requested. There is digital logic involved it is NOT wired like a 60's car.
Old Feb 15, 2020 | 03:19 PM
You're in Michigan... You sure they aren't frozen?
I'm in Ohio and mine are.
Old Feb 15, 2020 | 07:26 PM
Rear windows dont work from drivers door or by themselves
Replaced drivers control pad. Only drivers window moves all 3 others just click. All fuses are good. Power and ground at main switch are good. No broken wires between drivers door and body.
Old Feb 15, 2020 | 08:06 PM
I've merged your 2 threads. Oldblue, pretty sure these are the same person, you may need to merge id's? Or delete 1?
Old Feb 16, 2020 | 06:39 AM
The other account would not let me sign back in on your end. Kept saying pw invalid . Did forgot pw and that said invalid . So I created a new account. We will see if that works.
Old Feb 16, 2020 | 08:02 AM
There you go , accounts merged. I’ve sent an email to you about the username.
Old Feb 16, 2020 | 09:18 AM
I STILL don't know which widows don't work!
Old Feb 16, 2020 | 09:28 AM
The drivers window works, the other three just click , I’m thinking, clean the master switch
as is posted
and there’s a how to from Cat Man
https://www.chevyhhr.net/forums/how-...ontacts-62119/
Old Feb 16, 2020 | 10:24 AM
How about the window lock button got pressed? RTFM page 2-18
