Chevy HHR Network
-   -   Electrical problem (https://www.chevyhhr.net/forums/problems-service-repairs-42/electrical-problem-18748/)
DatonaBlue Oct 7, 2008 10:28 PM
Electrical problem
The lights on the temp controls starting blinking as I'm driving. No other lights on the dash blink just the 3 temp knobs. Any ideas?
ShefZ28 Oct 8, 2008 06:00 PM
blinking.. or flickering?
Blinking to me would appear like a controlled blink... think turn signal.
Flickering would appear more like a lose connection.
DatonaBlue Oct 8, 2008 06:24 PM
Flickering when you hit a bump. Where is the connection? What I don't understand is that it's only the 3 temp knob lights and all the rest are fine.
ChevyMgr Oct 8, 2008 06:28 PM
You can remove the faceplate, pull the control head and look at the pin connectors on the plug. From your description it would seem one of the pins is backed out of the connnector.
DatonaBlue Oct 8, 2008 11:24 PM
Thanks for the help I'll try that.
ShefZ28 Oct 9, 2008 09:32 AM
Drats, beat me to it. :lol:
hhrbama Oct 9, 2008 10:35 AM
Go into both fuse boxes (under hood and to the right on console) and re seat ALL your fuses. I haven't a clue why, but this loosening of fuses is an ongoing problem on the HHR. I had EXACTLY the symptoms you describe. Re-seating the fuses cured the issue. If one is loose several may be therefore press down and make sure they are all seated. I believe this will help you.
For the gentleman below with the "urban legend" comment, I had exactly the same issue with my car and re-seating the fuses solved the issue.
ChevyMgr Oct 9, 2008 10:39 AM
Urban legend.
cruzdreamer Oct 10, 2008 10:13 AM
I have the same problem...they blink from time to time! Let me know what you try and what works..thanks!
DatonaBlue Oct 10, 2008 06:47 PM
Well all I did was push all the fuses in to make sure they were tight and the lights don't flicker. At least they haven't in the last two days.
