Chevy HHR Network
-   -   Electrical problem or my car is haunted. (https://www.chevyhhr.net/forums/problems-service-repairs-42/electrical-problem-my-car-haunted-22713/)
onemancoyote Mar 28, 2009 08:44 PM
I started my car and it went crazy. The security light came on, as well as the check engine light. All of the gauges started bouncing up and down. The power steering went out and the transmission would not shift correctly. It kept saying low fuel/power steering. The coolant temperature read -42. lol. After getting it towed to the dealer Friday I went to check on it today and it started and drove fine. I checked my fuses and relays. Some of them were loose, but not horribly so. I also noticed a bolt on the side of my engine was rubbing into my wiring harness. The dealer is looking into it Monday for me. I know some other people have had this problem. What did the dealer have to do to fix it? If they can't reproduce the problem they tend to not believe there is one. I think its probably a loose harness, but I'm afraid it's something more.
2006 Chevy HHR
61,000 miles.
Snoopy Mar 29, 2009 12:26 AM
Just wondering did you buy it new? Are the electrical problems just, now, showing up?
Unfortuneately the 2006 HHR's were plagued with electrical problems. I have one....but have not had the problems that others have encountered.
But, as you suggested, it could be a harness connection problem.
onemancoyote Mar 29, 2009 08:47 AM
I bought it new and I've never had any trouble out of it till now.
roofer1976 Mar 29, 2009 09:28 AM
The exact same thing happened to my SS a few months back. There's a thread in the problems forum about it. In my case some wiring was not secure, and was in contact with moving parts. The wires were worn through, causing shorts. "Serial data/dlc/star connector wiring" was the culprit.
onemancoyote Mar 29, 2009 10:27 AM
awesome! thanks. I printed it off. I'm going to take it to the dealer with me.
roofer1976 Mar 29, 2009 07:07 PM
Hope the info helps.
MikeX Mar 30, 2009 08:30 AM
Can you post a pic of where the wiring is exactly, or describe where it is located exactly under the hood. I want to inspect mine.
Thanks.
roofer1976 Mar 30, 2009 08:35 AM
Thanks.
That, I don't know. It was repaired by the dealer. I took the description of the repair from the invoice.
09 Panel Mar 30, 2009 08:37 AM
Post 181 in this thread
https://www.chevyhhr.net/forums/show...ip4549&page=19
shows a picture of a wiring harness known to have an issue. Might be a spot to start.
onemancoyote Mar 30, 2009 12:58 PM
That was not the problem. The mechanic picked the harness apart and couldn't find anything wrong with it. He is stumped. He's trying to make the car do it again, but you know how that is. It sits at the dealership another day...
