Eng light 2.4 2006
Old Jan 28, 2010 | 08:13 PM
frey55's Avatar
Eng light 2.4 2006
My eng. light is on. I visited 2 diff. Auto Zones, Diag. Scanner shows blank screen every time, but eng. light will reset, only to come on next day. Noticed a small stumble in idle, and gas mi. reduced. Check fuses, and pushed them all in,all good, accept power outlet in front, replaced it. Any answers?
Old Jan 28, 2010 | 08:37 PM
Iceman's Avatar
Check the gas cap. you may have a bad or lose cap. normally it would have a code along with the light(so not sure thats it) If it is the cap the light will stay on for a few starts after fixing it....
Old Jan 29, 2010 | 01:12 PM
Kinison_fan's Avatar
I doubt its a loose cap-that is a common\known code that any reader should pick up.
Old Jan 29, 2010 | 03:51 PM
jay loukakis's Avatar
I had the same problum the the air filter inlet at the fender had come loose reinserted fixed the problum.
Old Jan 29, 2010 | 08:06 PM
frey55's Avatar
I will try these repairs, let you know what happens. Thanks again for the quick response.......
Old Feb 4, 2010 | 05:58 PM
frey55's Avatar
Eng lite still on. Pulling fuse on ecm resets light for a couple of days then light is on again. I do notice before it comes on a short stuble with engine..but no other drivability problems.
Old Feb 5, 2010 | 09:37 PM
Just a thought, try cleaning the MAF sensor, I hear that can make for stumbling idle. Also check for vacuum leaks and wires that have come into contact with hot points on the engine, causing a short, I think there might be a TSB on that.
Old Feb 7, 2010 | 07:06 PM
Sneezy's Avatar
do you have onstar? iF SO call and have them run a diagnostic. it came in handy when my hhr was acting up.
Old Feb 22, 2010 | 09:52 AM
frey55's Avatar
Maf
Thx... I ll check it out...but I did clean MAF , though, no. change
Old Feb 22, 2010 | 09:53 AM
frey55's Avatar
no on star
No on star thx though
myher
North East
Sep 28, 2014 12:26 AM
hoosierken
Jul 23, 2014 05:12 PM
gcarrington
Apr 25, 2014 12:45 PM
frey55
2.4L Performance Tech
7
Jun 6, 2010 04:48 PM
