engine or clutch issue or both standered tran
just recently i had my clutch replaced and for the last month its beeen working great. but latley when i start off the engin sounds like its bouncing around under the hood. "its like the clutch does not engage right or something is loose. this issue has never happenned befor. last night i was at a stand still starting to go up a little hill for a intersection and it sounded like the engin was bucking not the car. has any one else had this issue? if more info is needed let me know
Hard to say but it sounds like you are describing clutch "chatter".
Something is loose, or cracked plates.
this happends mainly when the moter has been running awhile. is there a possibility of blowing the motor if this issue gets worse?
Best to take it back to where you had the clutch replaced.
i am gonna do that now ill post wht it was once i figur out whts wrong
the shop says i am hearing things
Are you hearing this, or feeling it. Clutch chatter is easy to feel, but typically isn't accompanied by much sound. It could also be bad engine mounts, allowing the engine to move around and rock too much.
i more feel it then hear it. it its really weird but doesent happen all the time
i am taking it to another shop my car is getting looked at bumper to bumper
| All times are GMT -5. The time now is 09:36 AM. |
