engine cover
after losening all 4 of the screws behind the engine off...how do you get the cover off the engine so i can get to the spark plugs...i can get the back of the cover to lift...but the front seems to be stuck...
you have to disconnect the 2 hoses.
thank you!
Be careful & disconnect the MAF electrical connection.
Also you could spray some lube around the mounting studs, the rubber grommets tend to hang tight.. I lightly wipe them with a light grease to make future removals much easier. |
