Chevy HHR Network
-   -   engine noise (https://www.chevyhhr.net/forums/problems-service-repairs-42/engine-noise-56646/)
hurst2001 Mar 28, 2016 08:13 PM
engine noise
Hi got a 2007 her 2.2 auto at startup I get a ticking type noise until it driven for about 2 miles..Grant it I got 220,000 miles on her but starts on a dime...it sounds under the valve cover but going to use a steoscope to confirm.. timing chain was done at 170,000 and water pump and the new style tensioner.. I was reading that the gm engines sounds like this when the lifters are sticking ? When I rev it up still the same sound it does not change with rpm... so I was going to run some mmo to next oil change to clean and lube at the same time.. so any input on this thanks
donbrew Mar 28, 2016 09:15 PM
Sounds like 50,000 mile timing chain.
843de Mar 29, 2016 12:00 AM
I'm with Don, it's time, no pun intended, for a timing chain kit.
While the chains themselves don't "stretch" as some folks claim, the pins that hold the links together do wear out over time, leading to extra slop in the chain.
If it's noisy, then it needs attention A.S.A.P., having it fail will cause catastrophic engine damage. Think bent valves, damaged pistons, a cracked head, etc. It can get mighty ugly.
hurst2001 Mar 29, 2016 01:44 AM
. I don't think so I had replace my at 170000 when it was taken apart guides were good everything intack.. Sounds were coming under the valve cover .. I check my oil for anything out of the ordinary and seems ok.. I'm still thinking sticky litfters which common on some gm motors..had this sound on my ford ranger awhile back and took it to the dealer and the ran some kind of cleaner which cleared up the ticking noise.. Thanks for the comments but I will ride her out..
firemangeorge Mar 29, 2016 05:34 AM
First thing would be to use a stethoscope as you mentioned above. Locate exactly where the noise is coming from, then proceed.
chaosdsm Mar 29, 2016 05:42 AM
Are there even any engine components which don't change sound with engine RPM???
Oldblue Mar 29, 2016 10:35 AM
I'm thinking timing chain and balance shaft/ water pump chains and guides.
hurst2001 Mar 29, 2016 03:34 PM
If it was the timing would get louder when the engine 'revving? The sound is not a rattle but ticking sound. Maybe fuel injector noise ? They are the original ome..
donbrew Mar 29, 2016 04:11 PM
From post #6:
Oldblue Mar 29, 2016 07:33 PM
Ticking can be fuel injectors, yes and or lifters, yes can tick but will change with rpm! I'd order up one of these
00 11 GM 2 0L 2 2L 2 4L Ecotec Engine Timing Chain Kit w Balance Shaft Set L61 | eBay
It could be a tensioner headed south or a guide on the edge of breaking apart
