Engine power reduced code on my control panel??!
ENGINE POWER REDUCED CODE ON MY CONTROL PANEL just came up when i started my car this afternoon and my car is real slow to take off and accelerate! What does this mean? Anyone please help!
What about the Check Engine Light?
It usually means there is something wrong with the throttle actuator control system. I would start with cleaning the throttle body since the electronics parts would cause check engine lights. Other things involved: Throttle position sensor engine coolant sensor mass air flow sensor intake air temperature sensor vehicle speed sensor knock sensor MAP sensor or any of the wiring. |
Welcome to the site, there could be a code , possibly get it checked out at your local parts palace
