Engine Temperature Sensor
Old 11-26-2014, 02:16 PM
Technical Moderator
When you 're changing the t-stat that is most likely your real problem you will notice a brass thingie screwed into the side of the housing with an electrical connector on it, that's it. 12 or 13 mm wrench IIRC.
donbrew is offline
Old 11-26-2014, 02:26 PM
I'd change out the T-stat with a GM unit, far less problems then worry about the temp sensor, it is most likely just fine!
Oldblue is online now
Old 11-26-2014, 04:31 PM
alshhr's Avatar
no temp guage reading and dic read --------
had this problem few months ago. When I removed thermostat, I found that the built in gasket had been eaten away in spots. Replaced thermostat and all was good with guage and readout from dic. Also disconnected battery for couple of minutes for reset.
alshhr is offline
Old 02-13-2019, 11:29 AM
Father&son's Avatar
Coolant sensor and a/c not working
If you decide to replace the sensor and t/ stat make sure you spray some electrical spray liquid in the wire harness connecting the sensor. I have the same problems and replaced sensor and t stat many times.
Father&son is offline
Old 02-13-2019, 11:35 AM
^^^^^^ a very good point, welcome to the site!!
Old 02-13-2019, 04:40 PM
  #26
Cat Man HHR's Avatar
Why? Doesn't the sensor plug have a seal on it ?
Cat Man HHR is offline
Old 02-13-2019, 04:43 PM
  #27
It does but it can still corrode inside were the pins live!
Old 02-13-2019, 08:49 PM
  #28
Mattjones06's Avatar
I still haven’t figured out my problem analog gauge still don’t work but the digital read out works no codes and Yes the AC works. Changed the thermostat and sensor with GM parts.
Mattjones06 is offline
Old 02-13-2019, 10:32 PM
  #29
Technical Moderator
You said it moves up when hot ambient. Stop stressing about it, it is of no use anyway.
If you replace the instrument panel it will probably be fixed, pretty expensive, but your sanity is at risk, evidently.
donbrew is offline
Old 02-14-2019, 10:16 AM
  #30
Your right I let dumb stuff worry me.
Quick Reply: Engine Temperature Sensor
