Evap Canister Solenoid connector
Just a little tip for someone replacing this part. In order to keep from stretching out the rubber grommet that needs to be transferred to the new part, you can push it back towards the base and simply cut the end rib off with a hacksaw. Then it should slide off without stretching it (silicone spray also helps).
TiggersHHR
"How To" Tutorial Library
65
Feb 2, 2026 08:07 AM
