Chevy HHR Network
-   -   Evap Canister Solenoid connector (https://www.chevyhhr.net/forums/problems-service-repairs-42/evap-canister-solenoid-connector-60882/)
HHRnovice Oct 23, 2018 06:37 PM
Well, I learned a lot doing this and I do appreciate your help. Thank you.
dano40 Mar 22, 2021 02:00 PM
Just a little tip for someone replacing this part. In order to keep from stretching out the rubber grommet that needs to be transferred to the new part, you can push it back towards the base and simply cut the end rib off with a hacksaw. Then it should slide off without stretching it (silicone spray also helps).
