Faulty Speakers
I'm having a problem with my speakers now in my 2010 HHR, one time you turn on the car n they all work fine, the next time you turn it on only one speaker is working quietly on the dashboard. After getting my driver side door fixed, it wouldn't open on the outside, after getting that fixed the inside door handle busted off completely! Now it can't be opened from the inside until we can replace the handle. I don't know if it is also shorting out those speakers. Something is strange as it is one day works n one day doesn't work but it seems it happens at the start of the engine. The menu is all set so any suggestions? Can't afford a dealer 😂😂 |
Speakers are a common failure item due to moisture in the doors - and yeah they will work sporatically. Just replace them. There are several threads and posts here on replacing them. Also some good info on replacing that broken inside door handle.
Faulty Speakers
Originally Posted by whopper
(Post 845952)
Lotsa how to videos for the door handles.
Faulty Speakers
Originally Posted by Dena
(Post 845971)
thank you for the advice, we're going to do some troubleshooting today but it doesn't look good. We have a very trustworthy friend that fixed the door the first time, he'll be replacing the door handle soon. That door is the first thing I thought of since it's been such a pain but it's the one used the most. |
Faulty Speakers
Originally Posted by donbrew
(Post 816098)
I think that one actually continued in a different thread.
Is it a stock radio/HU? Is there an antenna in the front? They tried to sell me one without it. Is the antenna screwed in good? The only way to get to the antenna base/amp is through the headliner, just behind the mirror. Somebody recently said they had put a interior antenna on. |
I moved the post here; I think this is where you meant it to be.
The intermittent speakers indicate weather or moisture related damage, run them until their dead and won’t work any longer , then replace them , 6 3/4 inch speakers
Faulty Speakers
Originally Posted by Oldblue
(Post 845991)
Those scary computers sense that something is wrong then shutdown to save their life. Really.
The chimes are heard on the left speakers. You hear them mostly on the tweeters since they are high frequency. Usually it is the driver door speaker that gets glopped up because the window seals get disturbed from elbows out the window more. |
