Chevy HHR Network
-   -   Flywheel port cover? (https://www.chevyhhr.net/forums/problems-service-repairs-42/flywheel-port-cover-39859/)
coolzzy Mar 10, 2012 11:33 PM
I was changing my oil today, letting the car run for a few minutes to warm up the oil first. I was lying on the ground with my hand under the car feeling the oil pan, noticed air blowing on my hand. I shut the car off and inspected a little closer. There is a nice square access hole for the flywheel gear right there. Shouldn't there be some sort of cover or rubber plug covering this? If so does anyone have a part number so I can order one up?
ChevroletCustomerService Mar 12, 2012 10:39 AM
@coolzzy, if you don't want to contact your local Chevrolet dealership's service/parts department about this, you can provide me with your first and last names along with the VIN of the vehicle and I can see what I can find for you. Please, feel free to provide me with this information via PM.
coolzzy Mar 13, 2012 12:08 PM
Should there be a rubber plug to cover this or is it just an open access port or vent? Seems like moisture or road grit could get up in there otherwise.... anyone stick there head down there and confirm this?
sleeper Mar 14, 2012 12:10 AM
Michelle- ahhh, no offense.. But why couldn't ya look up the info with out
all this private info..
I don't ever hear many answers from you guys.. Just Sayin..
sleeper Mar 14, 2012 12:11 AM
Someone with a stick should be able to answer this...
843de Mar 14, 2012 12:54 AM
I've looked at the parts breakdown and I'm not seeing what he's describing, can you shimmy back under there coolzzy and take a photo for us?
IgottaWoody Mar 14, 2012 01:01 AM
Perhaps its ment to be open..inspection hole..drainage...cooling...
firemangeorge Mar 14, 2012 04:39 AM
FWIW. I have an SS w/5spd which I know is a different transmission than the regular HHR. Yes, I went out and stuck my head under there for a look because of the original post!:fixcar: No inspection hole on the bottom of mine.
But,there is a hole on the top side of the housing, with a plastic cover. Looking down from the drivers side, it is about the 10-11 o'clock position on the bell housing. Plus it's kinda hidden under a wire harness.
So yes, mine has an inspection hole,and yes, there is a cover,plug.
