front end alignment specs
anyone know what the specs are..?? are caster/camber adjustable or is it just the toe..?? thanks
Do a search here. There was a post not too long with the specs. I think it was posted by ChevyMgr because I ran off a copy.
Camber is adjustable with camber offset bolts.(Moog and some others make them) Parts store should have them. Caster adjustment: No |
thank you very much.....
[QUOTE=firemangeorge;681699]Oops. It was still on my desktop.
:twothumbs: Ha ! Fireman- I was just gonna post the same pic, I saved it too..:wink: |
I got my 2007 HHR with original FE1 suspension checked for alignment today but the mechanic did not find any spec and said the car was all right, almost everything looked green on the screen:
Front camber right : -1.4 Front camber left : -1.5 Front caster right : +3.6 Front caster left: +4.2 Wheel alignment front : +0.15 Rear camber right : +0.1 Rear camber left : +1.0 Wheel alignment rear: +0.08 |
Originally Posted by ScareDe2
(Post 913134)
Front camber right : -1.4 Front camber left : -1.5 Front caster right : +3.6 Front caster left: +4.2 Wheel alignment front : +0.15 Rear camber right : +0.1 Rear camber left : +1.0 Wheel alignment rear: +0.08 The specs are posted above. |
The only thing that is adjustable is toe.
Fe1….fe3…..
What the difference….I have 2011, HHR LT, 2.2
SS is FE5, all others are FE1/FE3.
