Front end clunking on a 2007 chevy hhr
This is what i found out today, wife's hht had a noise when hitting bumps or turning, complete inspection of the front suspension found that the lowe control arm rear bushings were wiped out, replaced both control arms problem solved
You would be very smart to change your user name. By publishing your email you give the guys in the internet cafe in Namibia permission to use it.
Scroll down to the bottom of a page click on "Contact Us" There is an option to change it. |
Thank you for signing up, glad to see you’re HHR is fixed ! |
Welcome!!! :thumb:
Glad you got it resolved. Keep in mind that the other common noise problems in the front end are caused by: the sway bar links (ball joints wear out and get sloppy), the sway bar bushings that hold it down to the frame. |
