Chevy HHR Network
-   -   frost inside windows (https://www.chevyhhr.net/forums/problems-service-repairs-42/frost-inside-windows-53136/)
salvy Feb 23, 2015 06:00 PM
frost builds up on inside of windshield and door windows...during day when parked they seem clear....at night without car being moved they frost up....have other members had this issue.....thanks
skyline26 Feb 23, 2015 06:26 PM
are your carpets wet? or mats wet?
any windows or sunroof left open? - even a tiny bit?
firemangeorge Feb 23, 2015 06:28 PM
Granted, I'm down south and don't deal with the weather you folks do....but.
Frost comes from frozen moisture, water, dampness or such.
I would be checking for any kind of water leakage to the inside of the car. Maybe pull up the edge of the carpets and see what's there. I'll bet you have some dampness somewhere.
Oldblue Feb 23, 2015 06:45 PM
I leave the drivers window open a half inch when I drive to let the moist air out when driving in this cold weather
salvy Feb 23, 2015 07:26 PM
All good points..drivers floor mat damp with all the snow around my way ..ill try the half inch open window trick....car will sit for 3,4 days at a time without being moved...thanks to all
SS fan Feb 23, 2015 08:20 PM
1 Attachment(s)
Too bad that weather around Boston.......You are a candidate for Weathertech mats they catch it all, you can pour it out when it melts.......:thumb:
donbrew Feb 24, 2015 01:31 PM
Don't discount a leaking A/C pan. It's running if you use the defroster.
salvy Feb 28, 2015 07:18 AM
weatherteck mat is my next move....after moving my floor mat most of dampness was where my heel of shoe rest on gas peddle carpet....So i sealed around wire harness that goes from door into car....im going to run defroster today take a long ride and look for any drips from a/c pan...thanks for all ideas guys
salvy Mar 1, 2015 01:42 PM
is a/c PAN LEAK do to blacked drain line...mostly on passenger side rug
donbrew Mar 1, 2015 03:04 PM
+1!
