Frozen Window
Frozen Window
I know I've read others that have had their windows freeze on them. I just had both rear fixed the switch or something because they would go down but took 10min or so to go back up. This was last week they was fixed. This weekend I put down the rear window and the damn thing stuck again...really pi***** me off. Now, my question for those of you who have had this happen has your vehicle sat outside all night. The 4 times this has happened my vehicle has sat out all night and I did it in the morning. Now I could see if it was COLD but it isn't. My driver's window did the same thing in December 1st and never happened again so I'm hoping this was a freak thing.
aschriver.....
I need to ask........is the dealer Dutch Cherolet/Pontiac?
Several years ago, while driving threw Maine I had a slight problem with a radio. I ATTEMPTED to have it fixed by them. In 2 days (which was an UNPLANNED vacation spot for me) they repeated told me it was fixed...and it was not. I finally, with a lot of coaxing, was allowed into the service area. I told and showed 2 technicians what to fix after about 15 minutes of diagnostics (it was a bad antenna to radio connector).
I THINK WHATEVER DEALER YOU ARE NOW USING FOR SERVICE, NEEDS TO BE CHANGED. It appears, by all the problems you are having, that your current dealer is exasperating your problems.
