Fuel Filter
Where's the fuel filter? Can I assume its in the fuel tank and not serviceable? I could not find a listing anywhere. MIKE.:confused:
No Fuel Filter
Good question:bow:
It appears you are correct. I've check the owner's manual AND the genuine Chevrolet HHR shop manual and I can't find a fuel filter. There is a mesh fuel screen in the "fuel pump module" (This contains the screen, electric fuel pump, the fuel level sensor (sender), and the fuel tank pressure sensor). If any one of these functions fail (except the pressure sensor which is replacable separately) the module must be replaced. GM PART # 15850486 CATEGORY: Fuel Tank Meter Sender/Connector DESCRIPTION: MODULE KI GM list is $320 Big buck$ The fact there is no true filter to protect the fuel injector$ seems silly to me. I sure would like to hear from a GM trained HHR technician to confirm or correct me if I'm missing something. How about it Mr. Goodwrench ? |
Originally Posted by Dave C
Good question:bow:
have you looked under the car to try and locate the filter?
Unless they have changed the design of their fuel injection systems, the fuel filter should be a separate "component" that can be replaced on it's own.
Where it is located, I have no idea. When I had the fuel filter replaced on my 2003 Malibu last year, it added about $70 (CDN) to the cost of the work I was having done at the time. |
New GM trucks have the filter intergrated with the pump. Not a "single" item to replace. It's replaced as the pump is replaced.:roll:
I bet the HHR is the same. |
fuel filter
I Am A Gm Master Tech. There Is No Fuel Filter. It Is All In The Pump Now. All The New Gm Car And Trucks Are Coming This Way Now.
Looks like a very good reason to invest in a locking gas cap. Fuel contamination would be really expensive. I don't understand the thinking. Chevy has had fuel filters for over 50 years to protect clunky old carburetors that could digest boulders, compared to our fuel injectors. :thumbsdow |
WTF is that. Man now I have to add a remote mount fuel filter. WTF was GM thinking.
If the pump is in the tank, a remote filter will help but if your fuel pump is in the tank it will not be protected.
