fuel pressure regulator
Old Dec 2, 2013 | 07:12 PM
car nut's Avatar
Im trying to find out where is the fuel pressure reg located i know its on the fuel rail but where. Is it under the rail or on back
Old Dec 3, 2013 | 05:54 PM
I moved this to it's own thread.
If it's a 2.2L or a 2.4L, I believe it's part of the fuel pump. Not sure about SS.
Try the SEARCH box at the top of the page.
Old Dec 3, 2013 | 06:16 PM
badassbowtie's Avatar
Welcome to the forum!
Once the fuel leaves the fuel pump, the fuel either hits the fuel rail (2.2l or 2.4l) or hits the high pressure fuel pump (2.0l turbo). the 2.0l turbo model has a high pressure fuel pump on the engine that regulates the pressure. LS/LT models should be regulated from the pump inside the tank...That is one of the bad parts about these cars, everything is inside the tank. No changing the filter out in 20 minutes like the old days.
What is the issue you are having? and did you check your fuses?
Old Dec 3, 2013 | 06:20 PM
start at post 9...good info here also
https://www.chevyhhr.net/forums/problems-service-repairs-42/2006-fuel-preasure-regulator-44131/
I'm feeling helpful today donbrew
Old Dec 3, 2013 | 06:32 PM
Since the OP's sig says he has a SS, I'll chime in.
According to the diagram in the repair manual, there is a fuel pressure sensor located on the fuel rail. I don't see a seperate listing for a fuel pressure regulator, so I'm assuming it's internal in the high pressure pump.
The same should apply with the other pump, the electric fuel pump in the tank. Regulator is built in it also.
Since the pressure readings I've seen on the RPD range from about 1800psi cold start down to around 400 after warm up, I'm not really sure how the parameters are set for it's regulation.
I would suggest consulting the SS service manual if you're doing any diagnostics on the system.
Fievel4
Fuel Economy - Hypermiling
Jan 5, 2015 03:42 PM
Carnage SS09
Jun 10, 2013 12:37 PM
scbill
Mar 6, 2013 12:51 PM
longhornss
13
Mar 8, 2012 12:43 PM
BLUEHHRSS5SPEED
Dec 19, 2010 08:46 AM
