Had a Boost problem and fixed it.
Old Jun 10, 2010 | 08:55 AM
camaro98z28's Avatar
The Lower Piping had a vacuum nipple on it and was broke so I cut it off and drilled out the hole to fit a metal fitting and it works like a charm. Kinda suck when you're driving on the freeway and you hav no boost. It also suck working on a hot car. I now have to find time to take it to the dealer to get it fixed. A
Old Jun 10, 2010 | 09:22 AM
BlackScreaminMachine's Avatar
Where does the Vaccume line go? Is it engine or emissions related? Honestly if it does not affect anything major, its probably fine. I would think you would have a leak, but no boost at all!?
Only time I have seen that is when a buddy with a aftermarket power pipe had it come off completely, the car fell on it's face, getting un-metered air. That sucked on a Saturday night in a dark parking lot with no tools.
Old Jun 10, 2010 | 02:48 PM
the hose that's near the TMAP on the lower IC piping. It broke a while ago so I thought I would glue it back but the glue doesn't like 112 deg heat. It lost all boost and I looked and it was off so I drilled it out and it works like a champ.
Shawn
Aug 21, 2014 02:43 PM
bigjacksauto
56
Nov 6, 2012 02:01 PM
nedwob
Feb 5, 2010 02:53 PM
Toybuilder
Feb 9, 2009 12:41 PM
R CA HHR
Jun 19, 2007 05:49 AM
