Hazard Button/Switch
I just noticed the Hazard button/switch in my dash is acting a little funny. It will either illuminate all the time, when the hazards are turned on (then turn off when the hazards are turned off), or when the hazards are turned off (then turn on when the hazards are turned off). The button also flickers from time to time randomly.
on a side note, I did just install steering wheel radio controls, could that be causing the issue? I have a 09 1LT. |
Loose wire, does it flicker over bumps, or when radio is cranked up?
Originally Posted by foolmoon_design
(Post 647347)
