Hazard Switch
Old Apr 29, 2017 | 07:37 PM
SuKi's Avatar
Hazard Switch
My hazard lights are on and I can't get them to go off.
I just installed a factory fog light switch in the dash, unhooked all components and drilled hole for new switch. Upon reinstalling, when I connected the hazard switch, they popped on and will not go off. I've taken apart the switch to see if I could find anything wrong. While I was drilling I did have the panel face down on my wooden workbench, so I may have damaged it. I have a new switch on order, it's Sunday and the chevy parts dept isn't open, and neither Napa nor Carquest have the switch in stock.
I have removed the fuse and the relay, 68 and 69 in the engine compartment fuse box, hoping the hazards might turn off, but they didn't. Does anyone have a thought as to how I might get the switch to tell the BCM to turn off the hazards while I wait for the new one. I have an extra vehicle, but I'm going to be dropping this off tomorrow for bodywork.
Any thoughts or ideas are appreciated.
Old Apr 29, 2017 | 09:56 PM
Just a guess here. Cut the ground wire at the hazard switch. Leave enough wire on each side to splice it back with a connector when you get the new switch.
It should be a black/white stripe wire.
If you try this, check the remaining lights for operation since I'm not sure exactly what else that ground wire could effect.
Like I said. Just a suggestion or guess since pulling fuses and relays didn't work.
Old May 1, 2017 | 10:26 PM
Psicloned's Avatar
Before doing any wire splicing, be sure to confirm you didn't accidentally swap the hazard switch with the traction(?) switch. One is dark grey & the other is light grey. Both switches are the same size but the color should match the color of the receptacle. Fwiw, & Fyi, I ran into this when putting my dash back together and realized I accidentally swapped them.
Old May 1, 2017 | 10:49 PM
SuKi's Avatar
'Hmm, I'm pretty sure I manipulated all the switches to troubleshoot, but I will double check when I get home. Also, I'm not splicing, I have the factory fog light wiring behind the dash. Hopefully I'll feel really stupid later this evening when this simple fix works.
Old May 2, 2017 | 07:13 AM
Well. I guess I misread the 1st post. Thought you were asking for a way to turn off the flashers that were stuck on.
Old May 2, 2017 | 07:15 AM
Welcome to Hazard!
Old May 2, 2017 | 01:56 PM
SuKi's Avatar
FMG, no you were correct. PSICloned, you are also correct. I had the wrong plugs together. I didn't realize that the plug and the socket were color matched. I now don't see how I overlooked that, and why the hazards didn't go off with the press of the traction control button. Thanks for the tip
Old May 2, 2017 | 02:43 PM
Fixed! Yeah!!
Old May 2, 2017 | 02:47 PM
We even have a smilie for that
Old May 3, 2017 | 12:08 AM
Psicloned's Avatar
Yay! Glad I was able to give some back to the community!
Sundance
Feb 25, 2014 09:11 PM
drummerboy0088
May 30, 2012 09:54 AM
Yonash
Apr 26, 2011 11:36 PM
