Help with alignment question, tire wear
Driver rear -.79 degree that bad?
-.79 Toe in the rear is the question, the outer belt is showing. Had the alignment done after the drivers front hit a curb. I replaced the Lower Control Arm, the passenger was changed due to wear. I think I'm good on the front, its the driver rear I'm worried about. Bought the car like this.
The last time I had alignment done I had the rear shims done... It wasn't out by much and had been out for quite some time without change over time. It was an option I chose to do this time around. Mine would have been fine without though, I wasn't having issues. Yours may be more serious and I don't know if the shims can "fix" it...
Should you try this ? No.
You need to find out what is bent or worn(hubs maybe) Since there is no adjustment on the rear axle, find out what/why is the cause.
Shimming is not going to fix the root problem. A good body or frame shop could tell you what it is.
Thank you, Hubs not a big deal. Ill check this week
Thank you, Hubs not a big deal. I'll check this week. So far its been a great car to teach the grandson on. We changed the water pump and front brakes , then he hit a curb and we changed out more or less the front end including the front bumper skin and headlights
