Help with flex pipe and TPMS
Old Nov 29, 2015 | 08:53 AM
hurst2001's Avatar
Ok got her done 115$ parts and labor .. I didn't want to start another thread but one more thing with this car ... On start up from sitting all night I get noise like if you hit a alumina can like a ticking noise ... After awhile of running it qiuts down ... Car is pushing 216000 the timing chain and water pump done at 170000 everything new .. May be the cam followers or injector noise? They are the original stuff .. Any inputs thanks
Old Nov 29, 2015 | 09:02 AM
Check you timing chain tensioner if it doesn't have the bump it's the old style and can give you the start up chatter!
Old Nov 29, 2015 | 09:38 PM
hurst2001's Avatar
I do have the new style chain tensioner when had the chain replaced new guides... wondering if maybe if it the belt tensioner it is the orignal...
Old Nov 30, 2015 | 07:27 AM
I found this how to for you
Most tensioners for the accessory drive belt are used for $20. To $30.00.
Did not find a new one online but I'm sure somebody will
Old Nov 30, 2015 | 11:44 AM
JerseyJames's Avatar
Ummm.. you do realize that engine in the video is a 3800 V-6 longitudinally mounted engine vs. our shoe-horned with grease 2.0-2.4 I-4 transverse mounting? First clue was the extension on the rachet for the pulley .... for a HHR ???
p.s I'm sorry, couldn't resist the temptation...
Old Nov 30, 2015 | 03:35 PM
Then the title is misleading, arrrggggh !
ChadG
Feb 26, 2015 02:38 PM
justinwfrazier82
2.4L Performance Tech
Oct 13, 2014 08:17 AM
Reaper's Ride
May 15, 2014 05:28 PM
NxlKing2304
Aug 27, 2013 01:24 AM
kduccini
Mar 31, 2012 10:09 PM
