Help needed for Vibrations
Old May 26, 2011 | 09:04 AM
SmootHHR's Avatar
Originally Posted by 843de
Just a thought here, check out the right rear, I know that it was curbed on the front corner, but maybe the rear made some contact too. You just might have a bent rim back there, or a failing rear hub.
That was a thought, but there was no contact made (that I could see) on the RR. No scuffs, scratches, anything. Hub could be shot either way...it does have almost 115k. Thanks for the input
Old May 26, 2011 | 08:27 PM
SmootHHR's Avatar
It does it when the car is in neutral at speed still. Heading to the shop tomorrow instead of Saturday.
Old May 26, 2011 | 10:10 PM
Zagohhr's Avatar
Another possibilities:
- Engine mount. Changing from N to D, there´s a shaking?
- Transmission bearing. Ussually happen at certain speed, almost always the same?
Old May 26, 2011 | 10:46 PM
Yeah, good thought on the engine mounts, also a failing clutch plate or throwout bearing can induce some vibrations. You'll track it down Smooth, just have patience and be methodical.
Old May 27, 2011 | 07:14 AM
SmootHHR's Avatar
I just hate blindly throwing money at a problem...
Old May 27, 2011 | 07:23 AM
LawDog88's Avatar
Rob on my old silverado, it drove me nuts feeling vibrations in my steering column. Thought it was a bad tire. Switched tires, still there. What it ended up being was a bent rim. Ice in winter, went sideways, and up a curb, also taking out a mailbox. I would have the rims checked for round'ness.
Old May 27, 2011 | 08:33 AM
SmootHHR's Avatar
That's my biggest fear, especially since I just put new tires on them.
Old May 27, 2011 | 09:33 AM
Zagohhr's Avatar
I propose you a quick experiment, and this would rid you this possibilty. Switch the front wheels with the rear. If you feel the same, definitively aren´t wheel or rims. Once my wife hit a curb, and this lead to have a vibration like yours. I just switched the wheels, and voila! problem solved. In the other way, I understand you perfectly about waste time & money. I´ve struggling with the same kind of issues (Vibrations) with my HHR, my wife´s car and my previous car (1998 Mercury Sable). In this in particular, I felt like the car was bouncing at Highway speeds and vibrating too. For this, was the Lower ball Joint and an Engine mount.
Old May 27, 2011 | 09:42 AM
LawDog88's Avatar
He's got a point. While switching them may work, you may still feel it.. my best idea is take the wheels off (yourself) and inspect them front and back for ANY out of round-ness.
Old May 29, 2011 | 06:20 PM
Don06's Avatar
Did they find anything yet? Since it went away for a while when the tires`were replaced, it sounds like they have something to do with it. There is a powder we use in large truck tires to balance them. It balances the tire as it rolls.
