Heres a good one !!!
So I recently put brand new tires on the HHR. Steel wheels, uniroyal 215/55/16, rubber valve stem with TPMS on the back. Had the mexican tire shop around the corner do it. He put new valve stems in also. When I lived in Beaumont I had a real tire guy, but have not found anyone very impressive up around Dallas yet. The mexican does very sloppy work. They whack the TPMS with the shoe of the tire machine if you dont stand over their shoulder and tell them. They never use the proper tool that threads onto the valve stem to pull it thru, they always just grab a pair of side cutters and pry it thru the hole, messing up the threads every time. If I had aluminum or chrome wheels no way in hell would I bring it to him. I know I really need to shop around. Here is the scenario and I know you are not gonna believe it. I put 40 psi in my tires. For a month I drive back and forth to work and the all hold 40psi +/- 1 pound all month long. I drive to Houston and the LR starts loosing pressure at a rate of about 1 psi every 5 minutes. Once it gets to 25psi, I pull over, pump it back up to 40psi and as I continue to drive to Houston down I-45 doing 80mph, it again starts to slowly loose pressure. I pumped it back up a total of thre times before I decided to try to drive in the slow lane doing 70mph. Guess what, I drove an hour and a half and it did not loose pressure. On the way back to Dallas I did an experiment and sure enough when I am doing 80mph, I loose air, when I drive 70mph I do not loose air. Why?
40 psi cold then warm up those tires and they could expand in psi this could cause air loss thru the beads or valve stem, the door sticker says 30 psi , I run at that pressure, and run 85 to 95 mph down the 77 into Charlotte NC at the 95 down thru Georgia and Florida and don’t loose any pressure |
Originally Posted by Oldblue
(Post 854759)
No trouble, you’d be surprised how air pressure effects your car , handling, braking, mpg, tire wear. It also effects ride harshness As for your tire shop, it’s not that he’s from Mexico, it’s that he is sloppy and inefficient! |
(Post 854765)
