My battery connection broke in my fob and I soldered it back together. I thought it was an anomaly but it appears it is a weakness in the design. I also had the alarm activate when unlocking with the key. Hate that!
Bumping this because I thought I had a bad fob, but it appears it's something else. The fob has been flaky lately - sometimes working and sometimes not.
Well, I discovered that when it won't work, the key works fine in the door, without any alarm! So I think the security module (or some such thing) is erratic. When the alarm is actually on, the fob works fine. Any ideas on what to do next? |
Originally Posted by 07azhhr
(Post 599979)
Try setting your door locks in the DIC to drivers only when turning off the car. This will allow you to already have all the other locks locked when you shut the car off. Then all you have to do is get out, shut your door, and lock it with the key.
Thanks Steve |
Originally Posted by 843de
(Post 598922)
:welcome8: to the forum tgp1994!
Here's a trick to try, lock the door with the key not the power lock button, then open the door with the key....the horn should stay blissfully quiet. If it doesn't work the first time, unlock all the doors, then lock each door manually and then lock the driver's door with the key. Then try unlocking the driver's door with the key, the horn should remain silent. |
Originally Posted by senfield
(Post 760075)
This is great as long as no one tries to enter the vehicle through the back hatch which doesn't lock manually.
Originally Posted by db/sb
(Post 760297)
Yes it does. You grab the handle and push it closed....that would be manual wouldn't it??
He said "the back hatch which doesn't lock manually" after awakening this over 7 month old thread to add that bit of superfluous/incomplete/misleading information. He didn't say unlock which can only be done with the remote unless you consider the emergency release.
